跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Are you having trouble connecting your controllers to your xbox one? In this guide I will be showing you how to replace the wifi card on your console.
    • Are you having trouble connecting your controllers to your xbox one? In this guide I will be showing you how to replace the wifi card on your console.
  2. First start by locating the side of the console with the sync button or USB slot. Then carefully pry the side panel from the Xbox until it is completely separated.
    • First start by locating the side of the console with the sync button or USB slot. Then carefully pry the side panel from the Xbox until it is completely separated.
  3. After removing the panel behind the silver sync button remove its brace by using a screw driver to slide it out toward the backside of the Xbox.
    • After removing the panel behind the silver sync button remove its brace by using a screw driver to slide it out toward the backside of the Xbox.
  4. To disconnect the top it has a series of clips to unhook the first is tricky, you want to start by pushing the piece with the red square back toward the device while simultaneously pulling the part with the circle toward you, lifting it in an upward direction to separate them.
    • To disconnect the top it has a series of clips to unhook the first is tricky, you want to start by pushing the piece with the red square back toward the device while simultaneously pulling the part with the circle toward you, lifting it in an upward direction to separate them.
  5. Now on the backside use a flat screwdriver to pry the back clips straight off to separate the lid. It helps to center the screwdriver in the middle of each clip.
    • Now on the backside use a flat screwdriver to pry the back clips straight off to separate the lid. It helps to center the screwdriver in the middle of each clip.
    • Now carefully lift the backside of the Xbox without removing the front, disconnect the blue ribbon on the front of the Xbox then remove the lid fully.
  6. Now looking at the front of your console lift the white connector straight out of place in an upward motion. The black one is a little more different carefully pull outward as if it were a button clip.
    • Now looking at the front of your console lift the white connector straight out of place in an upward motion.
    • The black one is a little more different carefully pull outward as if it were a button clip.
  7. Just like the last step you're going to want to disconnect the blackwire pulling it in an upward motion. Once you've done that unscrew the surrounding screws eat are located with arrows pointing at them in the image.
    • Just like the last step you're going to want to disconnect the blackwire pulling it in an upward motion.
    • Once you've done that unscrew the surrounding screws eat are located with arrows pointing at them in the image.
    • Great! Once you've done that it should look like the second image.
  8. Now everything is disconnected from holding the card down you want to carefully pull the card straight up from the console until separated.
    • Now everything is disconnected from holding the card down you want to carefully pull the card straight up from the console until separated.
  9. Once you've done that you want to go around and unscrew the following bolts to remove the main lid on the console. After you've removed the lid right under where the card is placed should be the connector for the card. Now hold the black wifi board connector in place with the lid and screw it into the metal lid holding it into place.
    • Once you've done that you want to go around and unscrew the following bolts to remove the main lid on the console.
    • After you've removed the lid right under where the card is placed should be the connector for the card.
    • Now hold the black wifi board connector in place with the lid and screw it into the metal lid holding it into place.
    • After that go through and screw down the metal lid and tighten all the bolts snug.
  10. After you screw in the connector carefully put the new wifi card back into place then screw the wifi card down to secure it.
    • After you screw in the connector carefully put the new wifi card back into place then screw the wifi card down to secure it.
    • Once you've screwed it all into place hook the black wire back up to the new wifi card by snapping it back onto the board, just push it down until it clicks.
  11. Now make your way back to the front and connect the front wires the white one should slide down and clip into place and the black will snap down.
    • Now make your way back to the front and connect the front wires the white one should slide down and clip into place and the black will snap down.
  12. Now for reassembly. First things we are going to take the front off the top plastic panel.
    • Now for reassembly.
    • First things we are going to take the front off the top plastic panel.
    • To disconnect this piece you must simultaneously lift all the following clips then tilt the piece outward and away and it should come free; this ones tricky and may take a helping had.
  13. Now take the top panel and clip it back into place it should all snap down.
    • Now take the top panel and clip it back into place it should all snap down.
    • When reassembling the front make sure you hook the blue ribbon back into place first then slide the bottom in first on the panel; after that push the clips until they snap and it is slipped in tight.
  14. Now take the brace for the sync button and slide it back in on the track once you've done that your sync button should click repeatedly, if not try it again. Just about there, for your last step shown in picture two, take the side panel and clip into place until all clips are snug and snapped in; once you've completed that you have finished replacing your wifi card and resembling your console. Just about there, for your last step shown in picture two, take the side panel and clip into place until all clips are snug and snapped in; once you've completed that you have finished replacing your wifi card and resembling your console.
    • Now take the brace for the sync button and slide it back in on the track once you've done that your sync button should click repeatedly, if not try it again.
    • Just about there, for your last step shown in picture two, take the side panel and clip into place until all clips are snug and snapped in; once you've completed that you have finished replacing your wifi card and resembling your console.
结论
4等其他人完成本指南。
Logan
于2018年03月06日注册
359 信誉积分
撰写一个指南
团队
Vegas Room H9 Vegas Room H9 的会员
Community
13 名成员
创作了15篇指南
The issue I’m having is my controllers appear to be synced, but do not work at all, unless they are connected with a USB cable during boot. Will this fix help?
Andrew Sharpe - 回复
添加评论
浏览统计数据:
过去的24小时: 10
过去的7天: 53
过去的30天: 193
总计 3,659
