跳转到主内容
Xbox One Upper Metal Case Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Xbox One Upper Metal Case Replacement, Upper Metal Case: 步骤 1 中的图像 1,3 Xbox One Upper Metal Case Replacement, Upper Metal Case: 步骤 1 中的图像 2,3 Xbox One Upper Metal Case Replacement, Upper Metal Case: 步骤 1 中的图像 3,3
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  2. Xbox One Upper Metal Case Replacement: 步骤 2 中的图像 1,3 Xbox One Upper Metal Case Replacement: 步骤 2 中的图像 2,3 Xbox One Upper Metal Case Replacement: 步骤 2 中的图像 3,3
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
  3. Xbox One Upper Metal Case Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
  4. Xbox One Upper Metal Case Replacement: 步骤 4 中的图像 1,2 Xbox One Upper Metal Case Replacement: 步骤 4 中的图像 2,2
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  5. Xbox One Upper Metal Case Replacement: 步骤 5 中的图像 1,2 Xbox One Upper Metal Case Replacement: 步骤 5 中的图像 2,2
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
结论
另外一个人完成了本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,125篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 247
