跳转到主内容
加入维修社区 - 创建账户
Xbox One S WiFi Card Replacement
你所需要的
    1. Xbox One S WiFi Card Replacement, Case: 步骤 1 中的图像 1,1
      • Flip the Xbox One S so that the bottom of the case is facing upward.
      询问修复机器人
      添加评论
    2. Xbox One S WiFi Card Replacement: 步骤 2 中的图像 1,1
      • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
      • It's possible that the clips may break when you remove the bottom from the case.
      • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
      添加评论
    3. Xbox One S WiFi Card Replacement: 步骤 3 中的图像 1,1
      • Once all of the clips are opened, remove the bottom part of the case.
      询问修复机器人
      添加评论
    4. Xbox One S WiFi Card Replacement: 步骤 4 中的图像 1,2 Xbox One S WiFi Card Replacement: 步骤 4 中的图像 2,2
      • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
      添加评论
    5. Xbox One S WiFi Card Replacement: 步骤 5 中的图像 1,2 Xbox One S WiFi Card Replacement: 步骤 5 中的图像 2,2
      • Gently separate the interior case from the white exterior case using the appropriate method.
      • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
      添加评论
    1. Xbox One S WiFi Card Replacement, WiFi Card: 步骤 6 中的图像 1,1
      • Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
      询问修复机器人
      添加评论
    2. Xbox One S WiFi Card Replacement: 步骤 7 中的图像 1,1
      • Remove the black T8 screws with orange circles around them (there should be 3 of them).
      • After removing the screws, gently detach the Wi-Fi card.
      添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
Victoria Law
于04/26/17注册
1,126 声望
创作了3篇指南
团队
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G3
4 名成员
创作了121篇指南
5指南评论
The T10 is too small for the WiFi card what should I use
Joe Smith - 回复 分享
T8 Torx Bit Screwdriver
Sebastian Rosso - 回复 分享
How long are the 15 mm screws supposed to be?
Natalie G - 回复 分享
15 mm long hense the name
Ethan Jones - 回复 分享
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
Noel Sappor - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 51
过去 30 天: 259
总计 23,201
