跳转到主内容
Xbox One S Interior Case Top Panel Replacement
你所需要的
  1. Xbox One S Interior Case Top Panel Replacement, Case: 步骤 1 中的图像 1,1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Interior Case Top Panel Replacement: 步骤 2 中的图像 1,1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Interior Case Top Panel Replacement: 步骤 3 中的图像 1,1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Interior Case Top Panel Replacement: 步骤 4 中的图像 1,2 Xbox One S Interior Case Top Panel Replacement: 步骤 4 中的图像 2,2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Interior Case Top Panel Replacement: 步骤 5 中的图像 1,2 Xbox One S Interior Case Top Panel Replacement: 步骤 5 中的图像 2,2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
  6. Xbox One S Interior Case Top Panel Replacement, Interior Case Top Panel: 步骤 6 中的图像 1,1
    • Flip the interior case so it is fan side upward.
  7. Xbox One S Interior Case Top Panel Replacement: 步骤 7 中的图像 1,1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
结论
11等其他人完成本指南。
Andrew
于04/26/17注册
5,223 声望
创作了3篇指南
团队
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G3
4 名成员
创作了56篇指南
一条评论
Pourquoi ma X boxe One s'allume plus
Karim hamadi - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 142
总计 5,974
