跳转到主内容
Xbox One S All Digital Edition Plastic Enclosure Replacement
你所需要的
  1. Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 步骤 1 中的图像 1,3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 步骤 1 中的图像 2,3 Xbox One S All Digital Edition Plastic Enclosure Replacement, Plastic Enclosure: 步骤 1 中的图像 3,3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Plastic Enclosure Replacement: 步骤 2 中的图像 1,2 Xbox One S All Digital Edition Plastic Enclosure Replacement: 步骤 2 中的图像 2,2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Plastic Enclosure Replacement: 步骤 3 中的图像 1,2 Xbox One S All Digital Edition Plastic Enclosure Replacement: 步骤 3 中的图像 2,2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Plastic Enclosure Replacement: 步骤 4 中的图像 1,1
    • Flip the metal enclosure so that the fan cover is on top.
结论
另外一个人完成了本指南。
Jules Hajjar
于10/10/19注册
1,549 声望
创作了8篇指南
团队
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G6
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 52
总计 2,365
