跳转到主内容
Xbox One手柄同步充电套装无法通过USB充电?
你所需要的
  1. Xbox One手柄同步充电套装无法通过USB充电?, Xbox One手柄同步充电套装无法通过USB充电?: 步骤 1 中的图像 1,1
    • Xbox One手柄同步充电套装已连接USB但无法充电
  2. Xbox One手柄同步充电套装无法通过USB充电?: 步骤 2 中的图像 1,2 Xbox One手柄同步充电套装无法通过USB充电?: 步骤 2 中的图像 2,2
    • 拆下电池仓盖并取出电池。
    • 重新连接USB线,并确保手柄正常开机。如果它能够开机,本修复方法将会奏效。
  3. Xbox One手柄同步充电套装无法通过USB充电?: 步骤 3 中的图像 1,3 Xbox One手柄同步充电套装无法通过USB充电?: 步骤 3 中的图像 2,3 Xbox One手柄同步充电套装无法通过USB充电?: 步骤 3 中的图像 3,3
    • 取一小块低密度泡沫密封条,将其粘性一侧朝下,粘在在手柄电池槽中间。
    • 装回电池。
    • 重新插入USB线,并在插入USB线时轻轻按住电池,以使其与手柄中的触点接触。这使您能够检查修复是否奏效。注意:在手柄启动后,USB线上的指示灯需要大约一秒钟才会亮起。
  4. Xbox One手柄同步充电套装无法通过USB充电?: 步骤 4 中的图像 1,1
    • 如果一切顺利,您可以重新安装电池盖。但要小心,因为重新安装会比较困难。不过不用担心,那些小卡扣比您想象的要坚固得多,请耐心并小心操作。如果无法安装,请尝试修剪胶带而不是强行安装。
结论
就是这样。现在您可以像原本设计的那样为您的手柄充电了。至少我们不必再给送钱微软来修复这个问题。
26等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Shikai Huang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
bbhsascha
于05/14/16注册
945 声望
撰写一个指南
35条评论
Let me know if you have any issues or any suggestions on how to make this guide better. I ran into this issue and as normal MS was less than useless. I ended up replacing the controller, the USB cable and the battery in hopes that something will fix it.
bbhsascha - 回复
Thanks mate, squeezed on the battery (in towards the controller) as I inserted the cable and the light appeared on the cable. Before I tried just plugging it in to no help in result of the led indicator on the cable. But this solved it, thought I had a faulty battery/controller for a sec. Saved me some bucks there, much appreciated
TknighT - 回复
Glad it worked for you. Thanks for leaving a comment. Please note though I had this issue but as it turns out it was my controller. I did end up buying a new one. But in a pinch or at 2am this will help and keep you from tossing the %#*@ thing out the window.
bbhsascha -
Doesn’t work. Tried a know working battery from my other controller (which works in that controller), to no avail. Tried another battery from another controller that it works, nothing. The problem is the controller, not my battery (which is new).
claudiojourneyman - 回复
THANKS! Did it like you told in your instruction and now the controller is charging! Thumbs up!
Ali - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 146
过去 30 天: 564
总计 74,060
