跳转到主内容
Xbox One Hard Drive Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Xbox One Hard Drive Replacement, Side Vent: 步骤 1 中的图像 1,3 Xbox One Hard Drive Replacement, Side Vent: 步骤 1 中的图像 2,3 Xbox One Hard Drive Replacement, Side Vent: 步骤 1 中的图像 3,3
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
  2. Xbox One Hard Drive Replacement, Wi-Fi Board: 步骤 2 中的图像 1,2 Xbox One Hard Drive Replacement, Wi-Fi Board: 步骤 2 中的图像 2,2
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
  3. Xbox One Hard Drive Replacement: 步骤 3 中的图像 1,3 Xbox One Hard Drive Replacement: 步骤 3 中的图像 2,3 Xbox One Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
  4. Xbox One Hard Drive Replacement: 步骤 4 中的图像 1,2 Xbox One Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
  5. Xbox One Hard Drive Replacement: 步骤 5 中的图像 1,3 Xbox One Hard Drive Replacement: 步骤 5 中的图像 2,3 Xbox One Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
  6. Xbox One Hard Drive Replacement: 步骤 6 中的图像 1,2 Xbox One Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
  7. Xbox One Hard Drive Replacement: 步骤 7 中的图像 1,2 Xbox One Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
  8. Xbox One Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
  9. Xbox One Hard Drive Replacement, Optical/Disc Drive: 步骤 9 中的图像 1,2 Xbox One Hard Drive Replacement, Optical/Disc Drive: 步骤 9 中的图像 2,2
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
  10. Xbox One Hard Drive Replacement: 步骤 10 中的图像 1,3 Xbox One Hard Drive Replacement: 步骤 10 中的图像 2,3 Xbox One Hard Drive Replacement: 步骤 10 中的图像 3,3
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
  11. Xbox One Hard Drive Replacement: 步骤 11 中的图像 1,3 Xbox One Hard Drive Replacement: 步骤 11 中的图像 2,3 Xbox One Hard Drive Replacement: 步骤 11 中的图像 3,3
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
  12. Xbox One Hard Drive Replacement, Hard Drive: 步骤 12 中的图像 1,2 Xbox One Hard Drive Replacement, Hard Drive: 步骤 12 中的图像 2,2
    • Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
结论
12等其他人完成本指南。
Gwendolyn Church
于01/27/14注册
1,500 声望
创作了6篇指南
团队
Cal Poly, Team 6-22, Maness Winter 2014 Cal Poly, Team 6-22, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G22
4 名成员
创作了11篇指南
一条评论
Do you possibly have a list of the relevant files that should be on the new hard drive? I put mine back it, did the whole plug in ethernet and let it sit, nothing. tried flashing update, nothing. factory reset file, E200 so i pulled it back apart and am looking at the file set up on my desktop trying to determine if there are any missing files. any help is appreciated.
Jeremy Murphy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 6,701
