跳转到主内容
加入维修社区 - 创建账户
Xbox One Elite Controller Series 2 Left Joystick Replacement
你所需要的
视频介绍
结论
7等其他人完成本指南。
@HectorNavarroMX
于06/25/18注册
4,499 声望
创作了26篇指南
13指南评论
Does this work for the series 1 elite controller also?
Nicola - 回复 分享
Can we please get some insight to what the silver tape that is put over certain leads?
- What is the silver tape?
- What is the silver tape used for?
- Which leads are the silver tape covering?
- What happens if silver tape is not used?
Noah Adams - 回复 分享
It is called Kapton Tape. It is used to protect components from heat during the rework process. If you don't use it, there is a chance of damaging the components. Even though the damage may not be seen by the naked eye. Hope this helps!
Ken Stopczynski - 分享
It is aluminum tape not kapton tape. It is covering a surface mount component mounted within the area of the pins you have to desolder to remove the analog stick. He is covering it up to protect it from the heat and also to keep it from desoldering and moving while replacing the analog stick.
Damon Rowan - 分享
ma per caso accetti spedizioni, perché anche a me mi si è rotto così
Gabriel Pisciotta - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 46
过去 7 天: 258
过去 30 天: 1,183
总计 60,084
