简介
如果您正在使用Xbox One手柄同步充电套装,但无法通过USB充电,请尝试以下简单快捷且经济实惠的修复方法。我不能保证百分之百成功,但至少我每次尝试这种方法时,都能修复问题。所以您可以尝试一下,看看是否奏效。如果不奏效,您也只是浪费了两到五分钟的时间。
首先,请确保手柄能够通过USB正常工作。拆下电池,连接USB线。如果手柄正常启动,那么恭喜!这种修复方法可能会帮助您。
搞一些硬纸板或一些低密度泡沫密封条(在家得宝卖2.23美元,17英尺长,所以很便宜)。对于这种修复方法,我将使用低密度泡沫密封条。
切一块密封条,注意是一小块,大概是你小指甲盖大小,将其粘在在手柄电池槽中间。然后将电池放进去,轻轻压紧。在您保持电池位置不变的同时插入USB线。等待片刻(大约需要一秒钟),USB线上应该会亮起橙色指示灯。如果指示灯亮起,可以在保持线插入时装回电池仓盖。这样,您可以看到连接是否中断。如果连接中断,请再再试一次,但使用稍薄一点的密封条。这样应该可以解决问题。
注意:重新安装电池盖时可能会变得更难,注意不要弄断卡扣。不过不必太过担心,它们还是比较坚固的。
另外,我建议将手柄连接到电脑,而不是Xbox。我不确定Xbox在多次处理从有线切换到无线手柄时的效果。
你所需要的
就是这样。现在您可以像原本设计的那样为您的手柄充电了。至少我们不必再给送钱微软来修复这个问题。
26等其他人完成本指南。
由衷感谢以下译者:
100%
Shikai Huang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
35条评论
Thanks mate, squeezed on the battery (in towards the controller) as I inserted the cable and the light appeared on the cable. Before I tried just plugging it in to no help in result of the led indicator on the cable. But this solved it, thought I had a faulty battery/controller for a sec. Saved me some bucks there, much appreciated
Glad it worked for you. Thanks for leaving a comment. Please note though I had this issue but as it turns out it was my controller. I did end up buying a new one. But in a pinch or at 2am this will help and keep you from tossing the %#*@ thing out the window.
Doesn’t work. Tried a know working battery from my other controller (which works in that controller), to no avail. Tried another battery from another controller that it works, nothing. The problem is the controller, not my battery (which is new).
