跳转到主内容
Xbox Intec 7.2" Color Game Screen Disassembly
你所需要的
  1. Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: 步骤 1 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: 步骤 1 中的图像 2,2
    • Top shell is held in place with 4 screws and 6 retaining tabs
    • Remove 2 rubber pads to uncover 2 hidden screws
    • Remove 4 #1 screws
  2. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 2 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 2 中的图像 2,2
    • Take a spudger and disengage the 6 retaining tabs
    • This will be the most time-consuming step. Be patient and take your time.
    • You will hear an audible pop when disengaging the tabs.
    • Remove top housing
  3. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 3 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 3 中的图像 2,2
    • Remove 2 #1 screws
    • Disconnect 4 wire harnesses
  4. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 4 中的图像 1,3 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 4 中的图像 2,3 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 4 中的图像 3,3
    • Disconnect speaker header
    • It's not necessary to remove the speakers from the housing unless you need to.
    • Disconnect header if speakers need to be removed. Otherwise, this will be done in the next step.
    • Remove 8 #1 screws
  5. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 5 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 5 中的图像 2,2
    • Disconnect 2 headers
    • Lift wires over retaining posts
  6. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 6 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 6 中的图像 2,2
    • Grab the edges of the board and lift up
    • Don't attempt to fully remove the board from the unit yet
    • Disconnect last header
  7. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 7 中的图像 1,1
    • It's not necessary to remove the screen from the housing unless you need to.
    • Remove 4 #1 screws to remove screen
  8. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 8 中的图像 1,2 Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 8 中的图像 2,2
    • Lift up on tab
    • Remove 3 #1 screws
    • Grab the edges and lift the board up
  9. Xbox Intec 7.2" Color Game Screen Disassembly: 步骤 9 中的图像 1,1
    • Feed wires through the hinge enough to remove board from unit
    • These 4 headers are soldered directly to the board
    • If this board needs to be entirely removed, feed the wires all the way through the hinge.
结论
另外一个人完成了本指南。
Navy Vet 2015
于06/25/15注册
7,852 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 51
总计 1,043
