跳转到主内容
加入维修社区 - 创建账户
Xbox Fan Replacement
你所需要的
视频概述
  1. Xbox Fan Replacement, Fan Replacement: 步骤 1 中的图像 1,1
    • Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
  2. Xbox Fan Replacement: 步骤 2 中的图像 1,1
    • Peel off the stickers on the bottom side of the Xbox and unscrew all six screws using a Torx 20 screwdriver bit. Set the screws off to the side so you don't misplace them.
  3. Xbox Fan Replacement: 步骤 3 中的图像 1,1
    • Turn the console upright and remove the lid.
    • If you are having some trouble getting the lid off, try gently shaking the device while you pull up.
  4. Xbox Fan Replacement: 步骤 4 中的图像 1,1
    • In order to remove the IDE cable, pull firmly on the cable straight back from the hard drive.
    • This may be slightly difficult; wiggling the cable back and forth will help to unfasten it.
  5. Xbox Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the screw from underneath the IDE cable using a Torx 10 screwdriver.
    • This screw is located between the hard drive and DVD drive.
  6. Xbox Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive by pulling it directly up and out of the case.
    • The hard drive is attached to a power cable, but you shouldn't need to remove the power cable to get the drive out unless you are replacing the hard drive.
  7. Xbox Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the cable the same way that the hard drive cable was removed. Simply pull the cable straight out from the DVD drive.
  8. Xbox Fan Replacement: 步骤 8 中的图像 1,2 Xbox Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the screws from each end of the DVD drive using a Torx 10 screwdriver.
  9. Xbox Fan Replacement: 步骤 9 中的图像 1,1
    • Once both screws have been removed pull straight upwards to remove the drive.
  10. Xbox Fan Replacement: 步骤 10 中的图像 1,1
    • Unscrew all eleven screws that hold the mother board in place. Use a Torx 10 screwdriver to unscrew them.
  11. Xbox Fan Replacement: 步骤 11 中的图像 1,1
    • Remove the power cord by gently lifting it out at a 45 degree angle.
    • After the power cord is removed gently lift out the mother board by placing your fingers around the edges inside the case and lifting straight up and out.
  12. Xbox Fan Replacement: 步骤 12 中的图像 1,1
    • Remove the old fan by pressing gently on the clips on each side with a flathead screwdriver and then carefully clip in a new fan.
结论
3等其他人完成本指南。
Keiko McMaster
于10/10/18注册
238 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 47
过去 30 天: 202
总计 8,437
