跳转到主内容
Xbox Elite Wireless Controller Series 2 Top Housing Replacement
你所需要的
  1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 步骤 1 中的图像 3,3
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: 步骤 2 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: 步骤 2 中的图像 2,2
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: 步骤 3 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: 步骤 3 中的图像 2,2
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 步骤 4 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 步骤 4 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 步骤 4 中的图像 3,3
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 5 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 5 中的图像 2,2
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 6 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 6 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 6 中的图像 3,3
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 7 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 7 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 7 中的图像 3,3
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 8 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 8 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 8 中的图像 3,3
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 9 中的图像 1,2 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 步骤 9 中的图像 2,2
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 步骤 10 中的图像 1,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 步骤 10 中的图像 2,3 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 步骤 10 中的图像 3,3
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
结论
14等其他人完成本指南。
Manuel Haeussermann
于07/13/22注册
19,496 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,545篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 119
过去 30 天: 533
总计 12,486
