跳转到主内容
加入维修社区 - 创建账户
Xbox Duke Controller 6-Pin Cable Replacement
你所需要的
  1. Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: 步骤 1 中的图像 1,3 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: 步骤 1 中的图像 2,3 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: 步骤 1 中的图像 3,3
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
  2. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 2 中的图像 1,3 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 2 中的图像 2,3 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 2 中的图像 3,3
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
  3. Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: 步骤 3 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: 步骤 3 中的图像 2,2
    • Remove the stick caps from the potentiometers.
  4. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 4 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 4 中的图像 2,2
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
  5. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 5 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
  6. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 6 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard from the bottom half of the controller.
  7. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 7 中的图像 1,3 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 7 中的图像 2,3 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 7 中的图像 3,3
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
  8. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 8 中的图像 1,1
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
  9. Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: 步骤 9 中的图像 1,3 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: 步骤 9 中的图像 2,3 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: 步骤 9 中的图像 3,3
    • Disconnect the cable from the memory card slot, sliding the black plastic holder out of the slot.
    • Remove the plastic piece from the cable.
  10. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 10 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 10 中的图像 2,2
    • Remove the memory card slot by sliding it away from the motherboard.
  11. Xbox Duke Controller 6-Pin Cable Replacement: 步骤 11 中的图像 1,2 Xbox Duke Controller 6-Pin Cable Replacement: 步骤 11 中的图像 2,2
    • Desolder the pins holding the cable in place, then pull the cable away from the motherboard.
    • Solder the new cable into the motherboard.
结论
2等其他人完成本指南。
Anthony Casino
于02/15/25注册
630 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025 UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025 的会员
UMASSD-GULBRANDSEN-S25S1G1
1 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 48
总计 498
