跳转到主内容
Xbox Disc Drive Replacement
你所需要的
  1. Xbox Disc Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Xbox Disc Drive Replacement: 步骤 2 中的图像 1,1
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
    The screw is in the outside corner. If you pry up only the half of the foot on that side, you can easily remove the (very long) screw, and the foot will stay attached.
    Ian Butler - 回复
    Ah I always used to damage the feet.
    Andrew Veiga - 回复
  3. Xbox Disc Drive Replacement: 步骤 3 中的图像 1,2 Xbox Disc Drive Replacement: 步骤 3 中的图像 2,2
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    It is also easy to feel for the screw hole with your finger and then cut a hole, or punch it out with the tip of the Torx driver to reveal the screw.
    Ian Butler - 回复
  4. Xbox Disc Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Xbox Disc Drive Replacement: 步骤 5 中的图像 1,2 Xbox Disc Drive Replacement: 步骤 5 中的图像 2,2
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  6. Xbox Disc Drive Replacement: 步骤 6 中的图像 1,2 Xbox Disc Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disc Drive Replacement: 步骤 7 中的图像 1,2 Xbox Disc Drive Replacement: 步骤 7 中的图像 2,2
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  8. Xbox Disc Drive Replacement: 步骤 8 中的图像 1,3 Xbox Disc Drive Replacement: 步骤 8 中的图像 2,3 Xbox Disc Drive Replacement: 步骤 8 中的图像 3,3
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  9. Xbox Disc Drive Replacement: 步骤 9 中的图像 1,2 Xbox Disc Drive Replacement: 步骤 9 中的图像 2,2
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
    Remember that the new drive will only work if it has been properly prepared, and the Xbox has been modified.
    Ian Butler - 回复
    there is NO way to legally replace the xbox hard drive. it is LOCKED to the motherboard and the xbox will not boot to the OS or make it past the BIOS if the HDD is not the one that came with it from the factory. you MUST use a mod chip and “home brew” to do a HDD swap and expect it to work
    James Vawter - 回复
    Could you point me to a good tutorial on using a modding an original Xbox? All I want to do is swap an HDD in original Xbox with another original Xbox HDD because I want my saved game data. Any way to figure this out? Seems like modding is a !&&* of a burden.
    michaelaugustin2000 -
    Can i replace the original hard drive with new one
    Andrew Veiga - 回复
  10. Xbox Disc Drive Replacement, Disc Drive: 步骤 10 中的图像 1,3 Xbox Disc Drive Replacement, Disc Drive: 步骤 10 中的图像 2,3 Xbox Disc Drive Replacement, Disc Drive: 步骤 10 中的图像 3,3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    I dont got the tools and i dont know how to do ut
    jacob lowery - 回复
  11. Xbox Disc Drive Replacement: 步骤 11 中的图像 1,1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • ONLY REMOVE IF DEAD!
    It is ok to remove the drive if it isn't dead. If repairs are required to the drive it needs to be removed from the drive's housing.
    Navy Vet 2015 - 回复
    Surely this needs to be removed to access the motherboard?
    Jonathan Cousins - 回复
    Yes, it does.
    Zerobuss -
结论
60等其他人完成本指南。
rmarstel
于10/29/09注册
5,674 声望
创作了5篇指南
团队
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G2
3 名成员
创作了24篇指南
7条评论
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
Navy Vet 2015 - 回复
The final comment mentions “only remove if dead.”   What about a disc drive that closes and opens immediately….in other words, won’t stay closed.  Is this a sign of a defective disc drive too?
Miguel - 回复
I am having the same issue, Miguel.
Did you buy a new drive or figure out a better fix?
Thanks
Ben C. -
I learned that you need to change out the drive belt in the disc drive. Over time it wears out and either won't open, stays open, or will open/close continuously. I changed my drive belt and it started working fine.
Turtlelaw -
Can anyone help..My Xbox can't read games..I took it apart and cleaned it, still can't read games
mr.mistermitchell@yahoo.com - 回复
I have the Xbox original..
I’m having the same problems too ??‍♂️
Pablo Pablo - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 126
过去 30 天: 575
总计 70,597
