跳转到主内容
加入维修社区 - 创建账户
Xbox Disassembly
你所需要的
视频概述
  1. Xbox Disassembly, Xbox Disassembly: 步骤 1 中的图像 1,1
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: 步骤 2 中的图像 1,1
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: 步骤 3 中的图像 1,2 Xbox Disassembly: 步骤 3 中的图像 2,2
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
  4. Xbox Disassembly: 步骤 4 中的图像 1,1
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: 步骤 5 中的图像 1,2 Xbox Disassembly: 步骤 5 中的图像 2,2
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: 步骤 6 中的图像 1,2 Xbox Disassembly: 步骤 6 中的图像 2,2
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: 步骤 7 中的图像 1,2 Xbox Disassembly: 步骤 7 中的图像 2,2
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: 步骤 8 中的图像 1,3 Xbox Disassembly: 步骤 8 中的图像 2,3 Xbox Disassembly: 步骤 8 中的图像 3,3
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: 步骤 9 中的图像 1,2 Xbox Disassembly: 步骤 9 中的图像 2,2
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
  10. Xbox Disassembly: 步骤 10 中的图像 1,3 Xbox Disassembly: 步骤 10 中的图像 2,3 Xbox Disassembly: 步骤 10 中的图像 3,3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Disassembly: 步骤 11 中的图像 1,1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: 步骤 12 中的图像 1,1
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: 步骤 13 中的图像 1,2 Xbox Disassembly: 步骤 13 中的图像 2,2
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: 步骤 14 中的图像 1,2 Xbox Disassembly: 步骤 14 中的图像 2,2
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: 步骤 15 中的图像 1,2 Xbox Disassembly: 步骤 15 中的图像 2,2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: 步骤 16 中的图像 1,2 Xbox Disassembly: 步骤 16 中的图像 2,2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: 步骤 17 中的图像 1,1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: 步骤 18 中的图像 1,1
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: 步骤 19 中的图像 1,2 Xbox Disassembly: 步骤 19 中的图像 2,2
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: 步骤 20 中的图像 1,1
    • Congratulations, your Xbox is now completely dismembered.
结论
56等其他人完成本指南。
rmarstel
于10/29/09注册
6,182 声望
创作了5篇指南
团队
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G2
3 名成员
创作了26篇指南
10指南评论
Awesomeness, thanks a lot!
godoyander - 回复 分享
Thanks a million - perfect!
xan_lucky16 - 回复 分享
Heatsink removal?
Matt Russell - 回复 分享
Face plate removal?
Herberth Alvarez - 回复 分享
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 52
过去 7 天: 307
过去 30 天: 1,648
总计 217,425
