跳转到主内容
Xbox 360 Wireless Controller Triggers Replacement
你所需要的
  1. Xbox 360 Wireless Controller Triggers Replacement, Battery: 步骤 1 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement, Battery: 步骤 1 中的图像 2,2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Triggers Replacement, Rear Case: 步骤 2 中的图像 1,1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Triggers Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Triggers Replacement: 步骤 4 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Triggers Replacement: 步骤 5 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement: 步骤 5 中的图像 2,2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Triggers Replacement: 步骤 6 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement: 步骤 6 中的图像 2,2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: 步骤 7 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Triggers Replacement: 步骤 8 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement: 步骤 8 中的图像 2,2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Triggers Replacement, Logic Board: 步骤 9 中的图像 1,2 Xbox 360 Wireless Controller Triggers Replacement, Logic Board: 步骤 9 中的图像 2,2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Triggers Replacement, Triggers: 步骤 10 中的图像 1,3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: 步骤 10 中的图像 2,3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: 步骤 10 中的图像 3,3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller Triggers Replacement: 步骤 11 中的图像 1,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 11 中的图像 2,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 11 中的图像 3,3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller Triggers Replacement: 步骤 12 中的图像 1,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 12 中的图像 2,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 12 中的图像 3,3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller Triggers Replacement: 步骤 13 中的图像 1,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 13 中的图像 2,3 Xbox 360 Wireless Controller Triggers Replacement: 步骤 13 中的图像 3,3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
结论
45等其他人完成本指南。
Brett Hartt
于04/12/10注册
127,897 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
5条评论
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
iorigrif - 回复
If i leave out the vibrations things will it cause the problems tonthe board ??
Michael Francis - 回复
These instructions were given in proper order and understanding
Arthur Murray Doan - 回复
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
Rathori - 回复
Left trigger on xbox 360 wireless controler not working
Rog - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 40
过去 30 天: 196
总计 82,984
