跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Xbox 360 Wireless Controller,请使用我们的维修手册
  1. Xbox 360 Wireless Controller Teardown, Removing the first screws: 步骤 1 中的图像 1,3 Xbox 360 Wireless Controller Teardown, Removing the first screws: 步骤 1 中的图像 2,3 Xbox 360 Wireless Controller Teardown, Removing the first screws: 步骤 1 中的图像 3,3
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Xbox 360 Wireless Controller Teardown, Removing the back: 步骤 2 中的图像 1,2 Xbox 360 Wireless Controller Teardown, Removing the back: 步骤 2 中的图像 2,2
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 步骤 3 中的图像 1,2 Xbox 360 Wireless Controller Teardown, Removing the vibration motors: 步骤 3 中的图像 2,2
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Xbox 360 Wireless Controller Teardown, Removing the PCB: 步骤 4 中的图像 1,2 Xbox 360 Wireless Controller Teardown, Removing the PCB: 步骤 4 中的图像 2,2
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
  5. Xbox 360 Wireless Controller Teardown: 步骤 5 中的图像 1,1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 步骤 6 中的图像 1,3 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 步骤 6 中的图像 2,3 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: 步骤 6 中的图像 3,3
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Xbox 360 Wireless Controller Teardown, Removing the D-Pad: 步骤 7 中的图像 1,1
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. Xbox 360 Wireless Controller Teardown, End result: 步骤 8 中的图像 1,1
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
Mart-Jan
于05/26/19注册
305 声望
撰写一个指南
3条评论
Excelente trabajos
RIGO NOLASCO - 回复
Very clear, helped me clean my controller. Thank you :)
Taydolf Swiftler - 回复
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
https://imgur.com/a/DxXdUNB
Michael Orban - 回复
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 198
过去 30 天: 1,006
总计 39,435
