当前版本的文档还未经巡查,您可以查看最新的已查核版本。
在这个步骤中使用的工具:
购买
在这个步骤中使用的工具:
Spudger
$2.99
购买
Insert a Spudger between the front and rear cases along the left edge of the controller.
Rotate the spudger toward the front of the controller, prying the two cases apart.
Insert a spudger between the front and rear cases, near the headphone jack.
Rotate the spudger toward the front of the controller to pry the two cases apart.
Grasp the controller by the battery compartment and the headphone jack.
Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
