简介
Can't cycle through your grenades in Halo 3? Install some new bumpers and stick your enemies!
配件
没有特定配件。
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Insert a Spudger between the front and rear cases along the left edge of the controller.
Rotate the spudger toward the front of the controller, prying the two cases apart.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
25等其他人完成本指南。
