跳转到主内容
加入维修社区 - 创建账户
Xbox 360 Wireless Controller Bumper Panel Replacement
你所需要的
  1. Xbox 360 Wireless Controller Bumper Panel Replacement, Battery: 步骤 1 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Bumper Panel Replacement, Rear Case: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 4 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 5 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 5 中的图像 2,2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 6 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 6 中的图像 2,2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Bumper Panel Replacement, Vibration Motors: 步骤 7 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement, Vibration Motors: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 8 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement: 步骤 8 中的图像 2,2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Bumper Panel Replacement, Logic Board: 步骤 9 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement, Logic Board: 步骤 9 中的图像 2,2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Bumper Panel Replacement, Bumper Panel: 步骤 10 中的图像 1,2 Xbox 360 Wireless Controller Bumper Panel Replacement, Bumper Panel: 步骤 10 中的图像 2,2
    • Orient the controller so that the front of the controller is facing toward you.
    • Lift the bumper panel off the front case.
结论
30等其他人完成本指南。
Brett Hartt
于04/12/10注册
131,420 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,996篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 41
过去 30 天: 203
总计 53,664
