跳转到主内容
Xbox 360 Wireless Controller Analog Stick Covers Replacement
你所需要的
  1. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: 步骤 1 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Battery: 步骤 1 中的图像 2,2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Rear Case: 步骤 2 中的图像 1,1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  4. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 5 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 5 中的图像 2,2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  5. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 6 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 6 中的图像 2,2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  6. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: 步骤 7 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Vibration Motors: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  7. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 8 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 8 中的图像 2,2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  8. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: 步骤 9 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Logic Board: 步骤 9 中的图像 2,2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  9. Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: 步骤 10 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement, Analog Stick Covers: 步骤 10 中的图像 2,2
    • Grasp the right analog stick and pull the cover off its mount peg.
  10. Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 11 中的图像 1,2 Xbox 360 Wireless Controller Analog Stick Covers Replacement: 步骤 11 中的图像 2,2
    • Remove the left analog stick cover using the same procedure previously described.
结论
89等其他人完成本指南。
Brett Hartt
于04/12/10注册
125,652 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Community
140 名成员
创作了16,876篇指南
2条评论
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
zachharrizusnavy - 回复
Hola buenas tardes feliz domingo. Es tan amable de contactarme co algún proveedor de respuestos para mando de la xbox 360. Como circuitos integrados gatillos chips de vinculación entre otros. Selo agradecería
Jose - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 61
过去 30 天: 317
总计 98,994
