跳转到主内容
Xbox 360 S RF Board Repair
你所需要的
  1. Xbox 360 S RF Board Repair, RF Module: 步骤 1 中的图像 1,1
    • Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
  2. Xbox 360 S RF Board Repair: 步骤 2 中的图像 1,2 Xbox 360 S RF Board Repair: 步骤 2 中的图像 2,2
    • The RF module is still connected to the Xbox by a large USB-type connector.
    • Pull the board directly away from the Xbox to remove it.
  3. Xbox 360 S RF Board Repair, PSU Check: 步骤 3 中的图像 1,1
    • First things first, check the power supply. When plugged into the wall but not plugged into the unit, it should emit an orange light (showing that it is in standby mode). This light should stay orange when plugged into the unit. If it turns red, you likely have a PSU fault.
  4. Xbox 360 S RF Board Repair, Faceplate Check: 步骤 4 中的图像 1,1
    • To access the RF board, follow the RF module replacement guide for the unit, linked here.
    • First try disconnecting and reconnecting the ribbon cable for the faceplate. If this doesn't affect the issue, continue with the guide.
  5. Xbox 360 S RF Board Repair, RF Board Repair: 步骤 5 中的图像 1,1
    • The safest solution is to purchase a new RF Board, but there is a more immediate solution available
    • Capacitor C57 on the RF Board frequently shorts out causing the entire board to fail, but it is not strictly necessary for the board to function. You can either desolder the capacitor or pop it off with a screwdriver. Just be careful not to damage any other capacitors
    • Note: the buttons on the board still may not work, the console may occasionally make eject or power sounds, but it will function with a wireless controller and turn on/off accordingly.
    • EMBEDONIX has a video more carefully describing this process, linked here.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 159
总计 2,825
