简介
Make your Xbox 360 S look shiny and new by replacing the outer panels.
你所需要的
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
28等其他人完成本指南。
2指南评论
Prying the top and bottom case apart with a metal spudger?, you'll ruin your xbox 360 slim case....your already voiding your warrenty, why not open it the right way??, their's is a pin-hole located at the back where the sticker is, just stick a pin into it and it will release that clip thats holding it together!
if you are going to do something like open your xbox360, do it right the first time.......
ATTENTION: The metal spudger is absolutely wrong for that second tab, you will never reach it. Instead, place your thumb over where the security sticker is on the top half of the case and apply pressure, the tab will snap out of place with the right amount of gradual force. This drove me nuts for an hour and I found the solution elsewhere.
