跳转到主内容
Xbox 360 S Laser Lens Replacement
你所需要的
  1. Xbox 360 S Laser Lens Replacement, How to get to your optical drive (follow link in the instructions): 步骤 1 中的图像 1,1
    • Xbox 360 S Optical Drive Replacement
    • In order to get to the laser to replace it you first have to remove the disk drive.
    • The link at the top is an IFIXIT guide that helps you to remove and replace the optical disk drive.
    • For a new laser lens that comes with an anti-static solder joint consult the video guide to remove the solder joint.
    • https://youtu.be/iL8wVC9PLBk
    • When you purchase a new lens some come with the solder joint and some do not.
    • In the case that it does you'll need to desolder it. We provided a video to help you.
  2. Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: 步骤 3 中的图像 1,3 Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: 步骤 3 中的图像 2,3 Xbox 360 S Laser Lens Replacement, Start of the repair - how to get to the laser: 步骤 3 中的图像 3,3
    • Now that you have completed steps 1 and 2
    • Remove the elastic band on the disk drive.
  3. Xbox 360 S Laser Lens Replacement: 步骤 4 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 4 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 4 中的图像 3,3
    • With the underside exposed, identity the 4 main screws.
    • Remove these 4 screws.
    • Remove the cover to expose the assembly
  4. Xbox 360 S Laser Lens Replacement: 步骤 5 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 5 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 5 中的图像 3,3
    • Locate the three ribbons connected to the board.
    • Use the plastic spudger to unclamp the ribbons from the board.
  5. Xbox 360 S Laser Lens Replacement: 步骤 6 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • The ribbons will now be able to slip out. With the tweezers, gently pull the ribbons to completely detach them.
  6. Xbox 360 S Laser Lens Replacement: 步骤 7 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 7 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 7 中的图像 3,3
    • Locate the screw that holds the motherboard to the disk drive
    • Using your screwdriver, remove the motherboard screw.
  7. Xbox 360 S Laser Lens Replacement: 步骤 8 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 8 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 8 中的图像 3,3
    • Use the spudger's flat side to get under the biggest plastic pin on edge of the board.
    • Push the pin backwards and off of the board.
    • Using your spudger again, push the second smaller pin backwards and off of the board.
    • Then, slide the board away from the pin slightly to be free of the last plastic element (the black corner thing).
  8. Xbox 360 S Laser Lens Replacement: 步骤 9 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 9 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 9 中的图像 3,3
    • With the board freed from it's trappings, locate the pin securing the wires connected the board.
    • Be careful to not yank the motherboard or else the wires will rip from their sockets
    • Use your spudger to press this pin backwards.
    • Lift the entire board up to free the wires.
    • Lay the motherboard adjacent to the disk drive.
  9. Xbox 360 S Laser Lens Replacement: 步骤 10 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 10 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 10 中的图像 3,3
    • Locate the 4 circular hex screws that secure the laser rail assembly.
    • Using your T6 hex screw driver remove these 4 screws.
  10. Xbox 360 S Laser Lens Replacement: 步骤 11 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 11 中的图像 2,2
    • Lift the rail assembly out of the disk drive. Set the disk drive aside.
  11. Xbox 360 S Laser Lens Replacement: 步骤 12 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 12 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 12 中的图像 3,3
    • Flip the laser rail assembly over to expose the screws.
    • Remove the screw connecting the laser lens to the plastic fastener.
  12. Xbox 360 S Laser Lens Replacement: 步骤 13 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 13 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 13 中的图像 3,3
    • Remove the screw connecting the metal fastener to the rail.
    • Remove the metal fastener that holds the rod to the rail after removing the screw.
  13. Xbox 360 S Laser Lens Replacement: 步骤 14 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 14 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 14 中的图像 3,3
    • Push the rail end to the side and out from under the metal latch.
    • Slide the lens off the rail. Set aside the rail assembly.
  14. Xbox 360 S Laser Lens Replacement: 步骤 15 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 15 中的图像 2,2
    • Using the spudger, release the plastic clamp holding the ribbon to the laser lens.
    • Using your fingers gently pull the ribbon out of the plastic clamp.
  15. Xbox 360 S Laser Lens Replacement: 步骤 16 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 16 中的图像 2,2
    • This is the lens
    • Remove the screw holding the metal fastener to the old lense.
    • Remove the now unsecured metal fastener.
  16. Xbox 360 S Laser Lens Replacement: 步骤 17 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 17 中的图像 2,2
    • Connect the ribbon to the replacement lens by sliding it in place then closing the plastic fastener.
    • Place the removed metal fastener on the new laser lens and use the removed screw to secure the fastener to the replacement lens.
  17. Xbox 360 S Laser Lens Replacement: 步骤 18 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 18 中的图像 2,2
    • Slide the replacement lens onto the right rail
    • Make sure to clip the other side of the lens onto the left rail
  18. Xbox 360 S Laser Lens Replacement: 步骤 19 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 19 中的图像 2,2
    • Slide the unsecured right rail back under the metal latch. (metal latch is pointed to by the arrow)
    • Place the metal fastener removed from the rail previously back in position and secure it with the screw that was removed.
  19. Xbox 360 S Laser Lens Replacement: 步骤 20 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 20 中的图像 2,2
    • Retrieve the plastic fastener and the accompanying screw.
    • Reattach the plastic fastener to the laser lens and use your philips head screw driver to re-secure the screw. The lens should now be attached to the rail.
  20. Xbox 360 S Laser Lens Replacement: 步骤 21 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 21 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 21 中的图像 3,3
    • Position the rail assembly within the disk drive
    • Use the 4 previously removed screws to secure the position.
  21. Xbox 360 S Laser Lens Replacement: 步骤 22 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 22 中的图像 2,2
    • Place the motherboard back in position.
    • Use the plastic pins to resecure the motherboard back to the disk drive.
    • Refer to steps 8 & 9 if more pictures for assistance are needed.
    • Just work backwards starting with only the first picture in 9, securing the wires into their enclosure using their pin.
    • Then work backwards through the pictures in step 8.
  22. Xbox 360 S Laser Lens Replacement: 步骤 23 中的图像 1,3 Xbox 360 S Laser Lens Replacement: 步骤 23 中的图像 2,3 Xbox 360 S Laser Lens Replacement: 步骤 23 中的图像 3,3
    • Reattach the 3 ribbon wires to the motherboard.
    • These are the 3 wires that were detached in steps 5 & 6
    • If more assistance is needed work backwards completely through steps 6 and then 5.
    • Reattach the screw removed from the motherboard in step 7. This is the only screw that'll completely secure the motherboard to the disk drive.
  23. Xbox 360 S Laser Lens Replacement: 步骤 24 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 24 中的图像 2,2
    • Replace the cover remove the cover
    • Flip the disk drive over and reattach the four screws removed from the cover in step 4.
  24. Xbox 360 S Laser Lens Replacement: 步骤 25 中的图像 1,2 Xbox 360 S Laser Lens Replacement: 步骤 25 中的图像 2,2
    • Flip the disk drive and reattach the elastic band.
    • You are done with replacing the laser lens.
    • Nice Job!
结论
If you followed all the steps you should have a working XBOX 360 S.
7等其他人完成本指南。
KEB
于07/31/17注册
341 声望
撰写一个指南
一条评论
Thanks, took me around 30 min to do this. Everything is written in detail. I like that.
GetToHellOut - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 124
总计 8,297
