本指南有最近更改,您可查看未经巡查的最新版本。
简介
Make your Xbox 360 S look shiny and new by replacing the outer panels.
你所需要的
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
Release the clip near the front right corner of the top edge securing the right case to the faceplate.
44等其他人完成本指南。
4条评论
Thank you to who ever posted this! The directions are clear, you just have to read than reread, go slowly and don't force anything and most importantly do not get frustrated. My grandpa always said "if it is worth doing, do it right the first time.", and "measure twice, cut once."
Dylan Howe - 回复
so true. :) I needed this guide to replace my Xbox 1 S shell because I got frustrated when taking apart the original.
me I -
