当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
It may be easier to use your fingernail to release the clips from the RF module.
Remove the RF module shield from the console.
Remove the following screws securing the motherboard to the metal casing:
Nine gold 11 mm T10 Torx screws.
Eight black 5.6 mm T8 Torx screws.
If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
Lift the motherboard assembly from its front edge.
Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
Remove the motherboard assembly from the metal casing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
