跳转到主内容
加入维修社区 - 创建账户
Xbox 360 Faceplate Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Xbox 360 Faceplate Replacement, Faceplate: 步骤 1 中的图像 1,2 Xbox 360 Faceplate Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
  2. Xbox 360 Faceplate Replacement: 步骤 2 中的图像 1,1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
  3. Xbox 360 Faceplate Replacement: 步骤 3 中的图像 1,1
    • Remove the faceplate from the front face of the console.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 46
总计 1,073
