跳转到主内容
Xbox 360 E CD Drive Replacement
你所需要的
  1. Xbox 360 E CD Drive Replacement, Top Panel: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E CD Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E CD Drive Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    In my case it was a T10 Screw, not T9
    Limer o - 回复
  5. Xbox 360 E CD Drive Replacement: 步骤 5 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 5 中的图像 2,2
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
    Tyler Goyette - 回复
  6. Xbox 360 E CD Drive Replacement, Bottom Panel: 步骤 6 中的图像 1,1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  7. Xbox 360 E CD Drive Replacement: 步骤 7 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 7 中的图像 2,2
    • Slide the spudger along the crevice to separate the grated face and the top body.
  8. Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 3,3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  9. Xbox 360 E CD Drive Replacement, Top Body: 步骤 9 中的图像 1,2 Xbox 360 E CD Drive Replacement, Top Body: 步骤 9 中的图像 2,2
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    C1 - C5 screws
    Jeff Gray - 回复
    And not T9 - the're T10 screws
    Limer o - 回复
    Missing some steps here…. Where are the clips holding the sides together? To go straight from “Remove bottom cover” to “Device is apart” is a bit… lacking.
    Aksel Barnes - 回复
    Yes, Aksel Barnes is correct. There are missing pictures and steps showing the removal of the plastic exterior from the metal section.
    yovel binjamin - 回复
    another "manual" missing the hardest steps
    Thijs van Ulden - 回复
    Just wanted to share my experience: after you "spudge" off the top and bottom you have to "spudge" off the front as well. Then you can follow the rest of the steps
    lilmolens - 回复
  10. Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 1,3 Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 2,3 Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 3,3
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  11. Xbox 360 E CD Drive Replacement: 步骤 11 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 11 中的图像 2,2
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  12. Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 3,3
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  13. Xbox 360 E CD Drive Replacement: 步骤 13 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 13 中的图像 2,2
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
  14. Xbox 360 E CD Drive Replacement, CD Drive: 步骤 14 中的图像 1,2 Xbox 360 E CD Drive Replacement, CD Drive: 步骤 14 中的图像 2,2
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
    Note: The ribbon cable connected to the CD drive can be in the color red (as it was on my board). Just make sure the other end is connected to the motherboard to be sure.
    yovel binjamin - 回复
    Como destrava a gaveta do cd
    Valtecir César Melo Martins - 回复
  15. Xbox 360 E CD Drive Replacement: 步骤 15 中的图像 1,1
    • Use tweezers to unplug the blue and pink wires.
  16. Xbox 360 E CD Drive Replacement: 步骤 16 中的图像 1,1
    • Lift the front end of the CD drive and take it out.
    Just note that you will have to swap the PCB inside the disc drive. If you do not go through with this the game will not start.
    You do also require some soldering skills as the wires for the motor and sensor for the disc tray are soldered to the PSB.
    Michael Mouton - 回复
结论
22等其他人完成本指南。
George
于02/02/14注册
536 声望
撰写一个指南
团队
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G11
4 名成员
创作了43篇指南
11条评论
i wish the bottom cover magically came off like in step 9
sandjo - 回复
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - 回复
Several steps missing between 8 and 9
Freddie Parsons - 回复
Like remove wifi adaptor.
william capewell -
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - 回复
Yeah, most definitely it jumps from removing the side grills to have completely disassembled the entire console case...
MagoSaronno -
All the videos I watch tell me to take the drive apart and use the old motherboard on the new drive, so it's the same old motherboard. But mine is broke so can I just use the same motherboard from the new drive?
Gregory Lansberry - 回复
No must change the board over or it will not work.Gregory Lansberry.
william capewell -
Did you not mention the fact that the drives won’t work unless programmed?
Jack Smith - 回复
I have had the need to replace the cd assembly on a few 360 e-models. The problem I run into occasionally is the new cd assembly will sometimes only play music discs. I'm not sure if there is a software lock on the assembly or not as installing a 2nd new drive fixes the problem. Are some 360 drive assemblies not compatible with certain mobo revisions? Also, once you get the sides off, a very long screwdriver does the trick on the clips to get it open.
Willam T. Purnell - 回复
Didn't mention you have to remove the original dvd mainboard and put into the new drive for it to be recognised
tim hoath - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 142
总计 21,138
