跳转到主内容
加入维修社区 - 创建账户
Xbox 360 E CD Drive Replacement
你所需要的
  1. Xbox 360 E CD Drive Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  2. Xbox 360 E CD Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  3. Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    询问修复机器人
    添加评论
  4. Xbox 360 E CD Drive Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    添加评论
  5. Xbox 360 E CD Drive Replacement: 步骤 5 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 5 中的图像 2,2
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    添加评论
  6. Xbox 360 E CD Drive Replacement, Bottom Panel: 步骤 6 中的图像 1,1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
    询问修复机器人
    添加评论
  7. Xbox 360 E CD Drive Replacement: 步骤 7 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 7 中的图像 2,2
    • Slide the spudger along the crevice to separate the grated face and the top body.
    询问修复机器人
    添加评论
  8. Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 8 中的图像 3,3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
    询问修复机器人
    添加评论
  9. Xbox 360 E CD Drive Replacement, Top Body: 步骤 9 中的图像 1,2 Xbox 360 E CD Drive Replacement, Top Body: 步骤 9 中的图像 2,2
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    添加评论
  10. Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 1,3 Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 2,3 Xbox 360 E CD Drive Replacement, Bottom Body: 步骤 10 中的图像 3,3
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
    询问修复机器人
    添加评论
  11. Xbox 360 E CD Drive Replacement: 步骤 11 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 11 中的图像 2,2
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
    询问修复机器人
    添加评论
  12. Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 1,3 Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 2,3 Xbox 360 E CD Drive Replacement: 步骤 12 中的图像 3,3
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
    询问修复机器人
    添加评论
  13. Xbox 360 E CD Drive Replacement: 步骤 13 中的图像 1,2 Xbox 360 E CD Drive Replacement: 步骤 13 中的图像 2,2
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
    询问修复机器人
    添加评论
  14. Xbox 360 E CD Drive Replacement, CD Drive: 步骤 14 中的图像 1,2 Xbox 360 E CD Drive Replacement, CD Drive: 步骤 14 中的图像 2,2
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
    添加评论
  15. Xbox 360 E CD Drive Replacement: 步骤 15 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to unplug the blue and pink wires.
    询问修复机器人
    添加评论
  16. Xbox 360 E CD Drive Replacement: 步骤 16 中的图像 1,1
    • Lift the front end of the CD drive and take it out.
    添加评论
结论
取消:我没有完成这个指南。
28等其他人完成本指南。
George
于02/02/14注册
671 声望
撰写一个指南
团队
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G11
4 名成员
创作了55篇指南
12指南评论
i wish the bottom cover magically came off like in step 9
sandjo - 回复 分享
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - 回复 分享
Several steps missing between 8 and 9
Freddie Parsons - 回复 分享
Like remove wifi adaptor.
william capewell - 回复 分享
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 58
过去 30 天: 318
总计 27,943
