跳转到主内容
Xbox 360 Bottom Vent Replacement
你所需要的
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Xbox 360 Opening Tool
    购买
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
    Repair Doctor - 回复
    Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
    Christopher Sage - 回复
  2. Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 1,3 Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 2,3 Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 3,3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: 步骤 3 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 3 中的图像 2,2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: 步骤 4 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 4 中的图像 2,2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: 步骤 5 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 5 中的图像 2,2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: 步骤 6 中的图像 1,1
    • Remove the bottom vent from the 360.
结论
68等其他人完成本指南。
一条评论
cool thanks for the tip
exavier smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 77
总计 28,101
