跳转到主内容
加入维修社区 - 创建账户
Xbox 360 Bottom Vent Replacement
你所需要的
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 1,3 Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 2,3 Xbox 360 Bottom Vent Replacement: 步骤 2 中的图像 3,3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: 步骤 3 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 3 中的图像 2,2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: 步骤 4 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 4 中的图像 2,2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: 步骤 5 中的图像 1,2 Xbox 360 Bottom Vent Replacement: 步骤 5 中的图像 2,2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: 步骤 6 中的图像 1,1
    • Remove the bottom vent from the 360.
结论
69等其他人完成本指南。
1指南评论
cool thanks for the tip
exavier smith - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 180
总计 30,983
