跳转到主内容
简介
This guide will help the owner of a Kitchen Gourmet XQ-673H replace the water tubes.
  1. Make sure the device is unplugged before continuing.
    • Make sure the device is unplugged before continuing.
    • Turn the Kitchen Gourmet upside down.
  2. Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device. Remove the bottom cover. Remove the bottom cover.
    • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. Using a Phillips #1 screwdriver, remove the six 12mm screws. Some screws are not visible from this photo, but their location is highlighted by the circles.
    • Using a Phillips #1 screwdriver, remove the six 12mm screws.
    • Some screws are not visible from this photo, but their location is highlighted by the circles.
  4. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  5. Using small needle nose pliers, squeeze the metal that is covering the tube. Carefully slide down the metal covering. Repeat this step for the other tube.
    • Using small needle nose pliers, squeeze the metal that is covering the tube.
    • Carefully slide down the metal covering.
    • Repeat this step for the other tube.
  6. Using your fingers, gently slide off the Water Tubes. Using your fingers, gently slide off the Water Tubes.
    • Using your fingers, gently slide off the Water Tubes.
  7. Carefully lift the bottom section off the device. Carefully lift the bottom section off the device.
    • Carefully lift the bottom section off the device.
  8. Using small needle nose pliers, squeeze the metal that is covering the tube. Carefully slide down the metal covering.
    • Remove both of the Water Tubes completely.
结论
另外一个人完成了本指南。
Sean Perry
于2015年01月31日注册
425 信誉积分
创作了4篇指南
团队
GJ! Very nice!
Sfapa - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 538
