跳转到主内容
XMAX V3 Pro Disassembly
你所需要的
  1. XMAX V3 Pro Disassembly, Battery Door: 步骤 1 中的图像 1,3 XMAX V3 Pro Disassembly, Battery Door: 步骤 1 中的图像 2,3 XMAX V3 Pro Disassembly, Battery Door: 步骤 1 中的图像 3,3
    • Remove battery door
  2. XMAX V3 Pro Disassembly, Battery Removal: 步骤 2 中的图像 1,2 XMAX V3 Pro Disassembly, Battery Removal: 步骤 2 中的图像 2,2
    • Remove the battery from the device
  3. XMAX V3 Pro Disassembly, Bottom Cover: 步骤 3 中的图像 1,3 XMAX V3 Pro Disassembly, Bottom Cover: 步骤 3 中的图像 2,3 XMAX V3 Pro Disassembly, Bottom Cover: 步骤 3 中的图像 3,3
    • Apply heat from a hair dryer to help soften the glue
    • Use a spudger to pry off bottom cover
    • This might result in physical damage of the plastic bottom and cover by deforming the material
  4. XMAX V3 Pro Disassembly, Bottom Screws: 步骤 4 中的图像 1,2 XMAX V3 Pro Disassembly, Bottom Screws: 步骤 4 中的图像 2,2
    • Remove four PH000 screws
    • Remove plastic cover
  5. XMAX V3 Pro Disassembly, Assembly Removal: 步骤 5 中的图像 1,3 XMAX V3 Pro Disassembly, Assembly Removal: 步骤 5 中的图像 2,3 XMAX V3 Pro Disassembly, Assembly Removal: 步骤 5 中的图像 3,3
    • Use your thumb to apple pressure in the direction of the arrow
    • The entire assembly should slide out of the metal case
  6. XMAX V3 Pro Disassembly, Vibration Motor Screws: 步骤 6 中的图像 1,1
    • Remove both P00 Screws
  7. XMAX V3 Pro Disassembly, Vibration Motor Removal: 步骤 7 中的图像 1,3 XMAX V3 Pro Disassembly, Vibration Motor Removal: 步骤 7 中的图像 2,3 XMAX V3 Pro Disassembly, Vibration Motor Removal: 步骤 7 中的图像 3,3
    • Use a spudger to remove the vibration motor and spring
  8. XMAX V3 Pro Disassembly, Airflow Overview: 步骤 8 中的图像 1,2 XMAX V3 Pro Disassembly, Airflow Overview: 步骤 8 中的图像 2,2
    • Here is an overview of the internal assembly on top of the metal case so you can see the airpath
    • The rubber gasket that can be seen better in step 11 stops air from entering the heating assembly from the motherboard area and only allows it to be drawn in the the side perforations.
    • Air enters though the area within the red square and then goes though the hole within the red circle
  9. XMAX V3 Pro Disassembly, Negative Battery Contact Removal: 步骤 9 中的图像 1,2 XMAX V3 Pro Disassembly, Negative Battery Contact Removal: 步骤 9 中的图像 2,2
    • Use your thumb to push in the gold contact
  10. XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: 步骤 10 中的图像 1,3 XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: 步骤 10 中的图像 2,3 XMAX V3 Pro Disassembly, Continued Removal of Negative Terminal: 步骤 10 中的图像 3,3
    • Use a spudger to completely remove the gold battery contact from case
  11. XMAX V3 Pro Disassembly, Airflow Gasket Removal: 步骤 11 中的图像 1,2 XMAX V3 Pro Disassembly, Airflow Gasket Removal: 步骤 11 中的图像 2,2
    • Remove rubber gasket, simply slide it down the heater assembly
  12. XMAX V3 Pro Disassembly, O-ring Removal: 步骤 12 中的图像 1,2 XMAX V3 Pro Disassembly, O-ring Removal: 步骤 12 中的图像 2,2
    • Remove rubber o-ring
  13. XMAX V3 Pro Disassembly, Motherboard Screws: 步骤 13 中的图像 1,1
    • Remove four P000 screws
  14. XMAX V3 Pro Disassembly, Desolding of Heater Assembly: 步骤 14 中的图像 1,3 XMAX V3 Pro Disassembly, Desolding of Heater Assembly: 步骤 14 中的图像 2,3 XMAX V3 Pro Disassembly, Desolding of Heater Assembly: 步骤 14 中的图像 3,3
    • Desolder positive battery terminal and both heater wires
    • Desolder both temperature probe wires
  15. XMAX V3 Pro Disassembly, Heater Assembly: 步骤 15 中的图像 1,2 XMAX V3 Pro Disassembly, Heater Assembly: 步骤 15 中的图像 2,2
    • Use your fingers to pull off the heater assembly
  16. XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: 步骤 16 中的图像 1,3 XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: 步骤 16 中的图像 2,3 XMAX V3 Pro Disassembly, Positive Battery Terminal Assembly: 步骤 16 中的图像 3,3
    • Remove both P000 screws
    • Pull out positive battery terminal assembly
  17. XMAX V3 Pro Disassembly, Heater Core: 步骤 17 中的图像 1,3 XMAX V3 Pro Disassembly, Heater Core: 步骤 17 中的图像 2,3 XMAX V3 Pro Disassembly, Heater Core: 步骤 17 中的图像 3,3
    • Use a nail or spudger to remove the heater core from the outside housing
    • There will be some epoxy on the bottom of the casing that is securing the wires
    • This epoxy needs to be placed before reassembling the device. It stops air from the electronics and motherboard area from entering your mouth.
  18. XMAX V3 Pro Disassembly, More Heater Assembly Pictures: 步骤 18 中的图像 1,2 XMAX V3 Pro Disassembly, More Heater Assembly Pictures: 步骤 18 中的图像 2,2
    • Some more photos of the heater assembly
结论
6等其他人完成本指南。
ShellingRook27
于08/21/19注册
2,124 声望
创作了7篇指南
团队
Repair For You Repair For You 的会员
Business
1 名成员
创作了12篇指南
1指南评论
I wonder how the air gets inside the heater core, it does not seem to have any holes!
WasName - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 67
过去 30 天: 374
总计 8,550
