跳转到主内容
X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement
你所需要的
  1. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Underbody: 步骤 3 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 4 中的图像 1,1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 5 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 5 中的图像 2,2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 6 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 7 中的图像 1,1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 8 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 8 中的图像 2,2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 9 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 9 中的图像 2,2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 10 中的图像 1,1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 11 中的图像 1,1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 步骤 12 中的图像 1,3 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 步骤 12 中的图像 2,3 X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column: 步骤 12 中的图像 3,3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement, Steering Column Spring: 步骤 13 中的图像 1,1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing.
  14. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 14 中的图像 1,1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Steering Column Spring Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the steering column spring.
结论
另外一个人完成了本指南。
Liam Martinez
于04/01/15注册
562 声望
创作了5篇指南
团队
Cal Poly, Team 24-3, Lancaster Spring 2015 Cal Poly, Team 24-3, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 261
