跳转到主内容
X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement
你所需要的
  1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Underbody: 步骤 3 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 5 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 5 中的图像 2,2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 6 中的图像 1,1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 7 中的图像 1,1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 8 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 8 中的图像 2,2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 9 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 9 中的图像 2,2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 10 中的图像 1,1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 11 中的图像 1,1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: 步骤 12 中的图像 1,3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: 步骤 12 中的图像 2,3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: 步骤 12 中的图像 3,3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Front Steering Motor: 步骤 13 中的图像 1,1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing
  14. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 14 中的图像 1,1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 15 中的图像 1,2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 15 中的图像 2,2
    • Remove the remaining three 1.6 mm Phillips #000 screws from the black motor casing
    • The second image shows the screws removed from the casing.
  16. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: 步骤 16 中的图像 1,1
    • Pull out the front motor, making sure to keep the gears intact
结论
Trent Peterson
于04/01/15注册
454 声望
创作了3篇指南
团队
Cal Poly, Team 24-3, Lancaster Spring 2015 Cal Poly, Team 24-3, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G3
3 名成员
创作了9篇指南
一条评论
How many volts is the battery?
DC2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 569
