跳转到主内容
Wyze Cam V2 Charging Port Replacement
你所需要的
  1. Wyze Cam V2 Charging Port Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Charging Port Replacement: 步骤 3 中的图像 1,2 Wyze Cam V2 Charging Port Replacement: 步骤 3 中的图像 2,2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Charging Port Replacement: 步骤 4 中的图像 1,2 Wyze Cam V2 Charging Port Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    $3.99
  5. Wyze Cam V2 Charging Port Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Charging Port Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
  8. Wyze Cam V2 Charging Port Replacement, Charging Port: 步骤 8 中的图像 1,1
    • Desolder the iron piece holding the charging port in place.
  9. Wyze Cam V2 Charging Port Replacement: 步骤 9 中的图像 1,1
    • Carefully detach the charging port from the motherboard.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 20
总计 222
