跳转到主内容
WowWee Miposaur Wheel Replacement
你所需要的
  1. WowWee Miposaur Wheel Replacement, Wheel: 步骤 1 中的图像 1,1
    • Remove the 1.2 mm Phillips screws surrounding the wheel and take off the wheel cover.
  2. WowWee Miposaur Wheel Replacement: 步骤 2 中的图像 1,1
    • Remove 1.2 mm Phillips screw from the white plastic piece in the center of the wheel and then remove the wheel entirely.
结论
另外一个人完成了本指南。
Samir Himes
于10/22/18注册
126 声望
撰写一个指南
团队
UC Davis, Team S4-G3, Lore Fall 2018 UC Davis, Team S4-G3, Lore Fall 2018 的会员
UCD-LORE-F18S4G3
3 名成员
创作了2篇指南
一条评论
This will require a TON of pressure on the screw. I tried it. The wheel is removable even without taking out the screw, since it does not require much force this way, either.
Michael Deitz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 493
