跳转到主内容
WowWee Miposaur Battery Replacement
你所需要的
  1. WowWee Miposaur Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Phillips head #1 screwdriver to remove 3 2mm screws from MiPosaur's underside panel.
    • You may need to use an extension on your screwdriver to work around small space between the panel and the dinosaur's leg.
    • You can remove the bottom screw completely, but the top two screws are captive and do not need to be removed entirely.
  2. WowWee Miposaur Battery Replacement: 步骤 2 中的图像 1,1
    • Firmly grasp the panel and pull apart from the base of the toy.
  3. WowWee Miposaur Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the device.
结论
Melissa Bender
于08/09/18注册
97 声望
撰写一个指南
团队
iFixit, Team S1-G1, Weber Summer 2018 iFixit, Team S1-G1, Weber Summer 2018 的会员
FIX-WEBER-SU18S1G1
5 名成员
创作了41篇指南
一条评论
Moving the MiPosaur along the ground will give it a burst of power, and so can create an electrical hazard when touching internal parts. If you keep moving it, the low battery sequence will commence and it will power off, even if the power switch is set to off. If you want to do this, drive it in fast circles.
Michael Deitz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 946
