跳转到主内容
WowWee MiP Robot Tire Replacement
你所需要的
  1. WowWee MiP Robot Tire Replacement, Wheel: 步骤 1 中的图像 1,2 WowWee MiP Robot Tire Replacement, Wheel: 步骤 1 中的图像 2,2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - 回复
  2. WowWee MiP Robot Tire Replacement: 步骤 2 中的图像 1,2 WowWee MiP Robot Tire Replacement: 步骤 2 中的图像 2,2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  3. WowWee MiP Robot Tire Replacement: 步骤 3 中的图像 1,1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  4. WowWee MiP Robot Tire Replacement, Tires: 步骤 4 中的图像 1,2 WowWee MiP Robot Tire Replacement, Tires: 步骤 4 中的图像 2,2
    • Remove the three 7.7 mm Phillips #1 screws.
  5. WowWee MiP Robot Tire Replacement: 步骤 5 中的图像 1,3 WowWee MiP Robot Tire Replacement: 步骤 5 中的图像 2,3 WowWee MiP Robot Tire Replacement: 步骤 5 中的图像 3,3
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
结论
5等其他人完成本指南。
Moira Keahon
于09/24/14注册
257 声望
创作了3篇指南
团队
一条评论
my MiP has plastic over his wheels
Clarrie O'HARE - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 6,030
