跳转到主内容
WowWee MiP Robot Power Switch Replacement
你所需要的
  1. WowWee MiP Robot Power Switch Replacement, Battery: 步骤 1 中的图像 1,2 WowWee MiP Robot Power Switch Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: 步骤 2 中的图像 1,2 WowWee MiP Robot Power Switch Replacement: 步骤 2 中的图像 2,2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: 步骤 3 中的图像 1,2 WowWee MiP Robot Power Switch Replacement, Wheel: 步骤 3 中的图像 2,2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - 回复
  4. WowWee MiP Robot Power Switch Replacement: 步骤 4 中的图像 1,2 WowWee MiP Robot Power Switch Replacement: 步骤 4 中的图像 2,2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: 步骤 5 中的图像 1,1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 步骤 6 中的图像 1,2 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: 步骤 6 中的图像 2,2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: 步骤 7 中的图像 1,3 WowWee MiP Robot Power Switch Replacement: 步骤 7 中的图像 2,3 WowWee MiP Robot Power Switch Replacement: 步骤 7 中的图像 3,3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: 步骤 8 中的图像 1,1
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: 步骤 9 中的图像 1,2 WowWee MiP Robot Power Switch Replacement, Power Switch: 步骤 9 中的图像 2,2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: 步骤 10 中的图像 1,1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 3-4, Wollert Spring 2016 USF Tampa, Team 3-4, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G4
4 名成员
创作了10篇指南
一条评论
where can i buy the power switch of MiP
Reinejoe Cacho - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 610
