当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Remove the 12.0 mm Phillips #2 screw.
Hold the wheel in place, or it will rotate as you attempt to remove the screw.
Remove the arms from the body.
Carefully open the body compartment.
Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
Using precision tweezers, disconnect the following three bundles of wires:
Connecting the battery pack to the motherboard.
Connecting the power switch to the motherboard.
Connecting the speaker to the motherboard.
Gently remove the speaker from the MiP.
During reassembly, be sure to place the speaker in the same position.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
