跳转到主内容
World Dryer Airforce J4-973A3 Server Board Replacement
你所需要的
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: 步骤 1 中的图像 1,3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: 步骤 1 中的图像 2,3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: 步骤 1 中的图像 3,3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 2 中的图像 1,2 World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 2 中的图像 2,2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 3 中的图像 1,3 World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 3 中的图像 2,3 World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 3 中的图像 3,3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 4 中的图像 1,3 World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 4 中的图像 2,3 World Dryer Airforce J4-973A3 Server Board Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
结论
Blane Hirsh
于09/17/18注册
260 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 271
