跳转到主内容
World Dryer Airforce J4-973A3 Sensor Board Replacement
你所需要的
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: 步骤 1 中的图像 1,3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: 步骤 1 中的图像 2,3 World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: 步骤 1 中的图像 3,3
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 2 中的图像 1,3 World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 2 中的图像 2,3 World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 2 中的图像 3,3
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 3 中的图像 1,2 World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 3 中的图像 2,2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 4 中的图像 1,3 World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 4 中的图像 2,3 World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 4 中的图像 3,3
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the sensor board from your device.
结论
Luke Clancy
于09/17/18注册
123 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 479
