简介
If simple sensor maintenance fails to solve the problem with your dryer, replacement may be necessary. This guide details steps taken for replacement of the sensor board for the World Dryer Airforce J4-973A3.
你所需要的
In order to change the air filter, start with the removal of the outer metal casing.
Using the special bit, remove the large screws at the bottom of the casing.
To remove the case, lift the indicated spot with your hands.
即将完成!
结论
