跳转到主内容
World Dryer Airforce J4-973A3 Air Filter Replacement
你所需要的
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 步骤 1 中的图像 3,3
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: 步骤 2 中的图像 1,3 World Dryer Airforce J4-973A3 Air Filter Replacement: 步骤 2 中的图像 2,3 World Dryer Airforce J4-973A3 Air Filter Replacement: 步骤 2 中的图像 3,3
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: 步骤 3 中的图像 1,2 World Dryer Airforce J4-973A3 Air Filter Replacement: 步骤 3 中的图像 2,2
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
结论
Blane Hirsh
于09/17/18注册
260 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 229
