跳转到主内容
加入维修社区 - 创建账户
Wooting 60HE Keycap Replacement
你所需要的
  1. Wooting 60HE Keycap Replacement, Keycap: 步骤 1 中的图像 1,1
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
  2. Wooting 60HE Keycap Replacement: 步骤 2 中的图像 1,2 Wooting 60HE Keycap Replacement: 步骤 2 中的图像 2,2
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
  3. Wooting 60HE Keycap Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
  4. Wooting 60HE Keycap Replacement: 步骤 4 中的图像 1,1
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
  5. Wooting 60HE Keycap Replacement: 步骤 5 中的图像 1,2 Wooting 60HE Keycap Replacement: 步骤 5 中的图像 2,2
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
  6. Wooting 60HE Keycap Replacement: 步骤 6 中的图像 1,1
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
  7. Wooting 60HE Keycap Replacement: 步骤 7 中的图像 1,3 Wooting 60HE Keycap Replacement: 步骤 7 中的图像 2,3 Wooting 60HE Keycap Replacement: 步骤 7 中的图像 3,3
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
终点
Aryav Balia
于10/25/23注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S1G1
6 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 51
总计 1,233
