跳转到主内容
Wood Stool Leg Glide Replacement
你所需要的
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: 步骤 1 中的图像 1,1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: 步骤 2 中的图像 1,1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: 步骤 3 中的图像 1,1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: 步骤 4 中的图像 1,1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: 步骤 5 中的图像 1,1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: 步骤 6 中的图像 1,1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: 步骤 7 中的图像 1,2 Wood Stool Leg Glide Replacement: 步骤 7 中的图像 2,2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
结论
Molly Ristig
于10/07/19注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 386
