跳转到主内容
Wolfgang Puck Pie Maker Disassembly
你所需要的
  1. Wolfgang Puck Pie Maker Disassembly, Wolfgang Puck Pie Maker Disassembly: 步骤 1 中的图像 1,1
    • Open up the pie maker using the two main handles so it's open as shown in the picture.
  2. Wolfgang Puck Pie Maker Disassembly: 步骤 2 中的图像 1,2 Wolfgang Puck Pie Maker Disassembly: 步骤 2 中的图像 2,2
    • Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
    • Remove the inside handle cover.
  3. Wolfgang Puck Pie Maker Disassembly: 步骤 3 中的图像 1,2 Wolfgang Puck Pie Maker Disassembly: 步骤 3 中的图像 2,2
    • Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
    • This will allow for visibility into the wiring in the base.
  4. Wolfgang Puck Pie Maker Disassembly: 步骤 4 中的图像 1,2 Wolfgang Puck Pie Maker Disassembly: 步骤 4 中的图像 2,2
    • Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
    • Remove the top cover by pulling it off of the device.
  5. Wolfgang Puck Pie Maker Disassembly: 步骤 5 中的图像 1,2 Wolfgang Puck Pie Maker Disassembly: 步骤 5 中的图像 2,2
    • You now have access to the wiring underneath the top and bottom of the device.
    • To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
    • The temperature sensor can be accessed by lifting the bottom side of the device as shown.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 189
