跳转到主内容
Wolf Gourmet WGTR102S Lighting Component Replacement
你所需要的
  1. Wolf Gourmet WGTR102S Lighting Component Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 3 中的图像 1,1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 4 中的图像 1,1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 5 中的图像 1,1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 6 中的图像 1,1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 7 中的图像 1,1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 8 中的图像 1,2 Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 8 中的图像 2,2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Lighting Component Replacement, Lighting Component: 步骤 9 中的图像 1,1
    • Remove two 8mm screws securing the lighting component using a Tri-point Y1 screwdriver.
  10. Wolf Gourmet WGTR102S Lighting Component Replacement: 步骤 10 中的图像 1,1
    • Remove the lighting component from the device.
结论
Ryan Funchess
于04/19/18注册
697 声望
创作了5篇指南
团队
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018 的会员
CPSU-MANESS-S18S22G5
4 名成员
创作了5篇指南
一条评论
Hi, do you have an idea how to remove the beeping sound? It's annoying, I want to remove it
Thank you
francis - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 10
总计 241
