跳转到主内容
Wobbly Wheel Replacement & Frame Tightening
你所需要的
  1. Wobbly Wheel Replacement & Frame Tightening, Wheel & Frame Repair: 步骤 1 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening, Wheel & Frame Repair: 步骤 1 中的图像 2,2
    • Stick the 13mm wrench fitting over the nut of the wheel.
    • Turn the wrench right to left to loosen the nut until it comes off.
    • Completely unscrew the nut from the axel.
  2. Wobbly Wheel Replacement & Frame Tightening: 步骤 2 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening: 步骤 2 中的图像 2,2
    • Hold the wheel and pull it off the axle.
    • Utilize a bearing puller or a plier to loosen up the bearings.
    • Take out the bearings from the wheel.
    • Use a clean cloth to wipe down the axle to remove any dirt, debris, or old grease.
  3. Wobbly Wheel Replacement & Frame Tightening: 步骤 3 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening: 步骤 3 中的图像 2,2
    • Oil the bearings with WD-40 to remove any rust or dirt.
    • Make sure to oil them front and back to get rid off any unwanted sludge or corrode.
  4. Wobbly Wheel Replacement & Frame Tightening: 步骤 4 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening: 步骤 4 中的图像 2,2
    • Make the bearings spin with your finger.
    • Clean any extra oil/debris off the bearings.
    • Ensure the bearings move/rotate freely.
  5. Wobbly Wheel Replacement & Frame Tightening: 步骤 5 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening: 步骤 5 中的图像 2,2
    • Put the bearings back in the new wheel.
    • Push them into the wheel firmly to ensure their proper placement.
    • Rotate the wheel to verify.
  6. Wobbly Wheel Replacement & Frame Tightening: 步骤 6 中的图像 1,3 Wobbly Wheel Replacement & Frame Tightening: 步骤 6 中的图像 2,3 Wobbly Wheel Replacement & Frame Tightening: 步骤 6 中的图像 3,3
    • Inspect the frame and look for any loose bolts.
    • Use the wrench/pliers to tighten any loose bolts until they are snug.
    • Do not overtighten, as this can damage the frame or the boot.
  7. Wobbly Wheel Replacement & Frame Tightening: 步骤 7 中的图像 1,2 Wobbly Wheel Replacement & Frame Tightening: 步骤 7 中的图像 2,2
    • Place the new wheel onto the axle.
    • Add any washers, if applicable.
    • Screw the nut back onto the axle using the wrench, tightening it until the wheel feels secure.
    • Make sure wheel spins smoothly and doesn't wobble or rub against the frame or boot.
    • Repeat for all other wheels.
结论
Sports equipment can be expensive to buy, and instead of buying a new pair of skates, users can easily just repair the old ones. Learning this basic skill can be beneficial as it saves money and time, while ensuring less waste on our planet.
另外一个人完成了本指南。
Muskanmeet Kaur
于01/29/23注册
175 声望
撰写一个指南
团队
York University, Team P-8, Allen Winter 2023 York University, Team P-8, Allen Winter 2023 的会员
YORK-ALLEN-W23SPG8
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 328
